How to Choose a Car Charger for iPhone X
With the increasing applications of mobile devices, charging has never been so important in our daily life. Whether you’re going to work or heading off on a road trip, you can’t be without a car charger before you leave home. Since the release date of iPhone X, we know that it comes with new charging features — fast charging and wireless charging. If you want to take advantage of the fast charging technology from a car charger, you must know how to choose one for your iPhoneX. Here are questions you need to answer:
- Is fast-charging enabled?
- Is there more than one socket?
- Is the car charger a suitable size?
- How long is the cable length I need? (If the car charger comes with a built-in cable)
These are all important features worth considering while choosing a car charger for your iPhone X.
Fast Charging: Apple declared that iPhone X can achieve 50% power charge in only 30 minutes with a USB-C to lightning cable. If you want to enjoy this fast speed, you need to spend a lot buying a USB-C to lightning cable and a USB-C power delivery compatible charger.
Here are some best fast charging supported car chargers for iPhone X:
Zendure 30W Car Charger with QC 3.0
Zendure originated through contributions of thousands of fans and has been one of the most successful external battery projects on Kickstarter. This car charger is perfectly compatible with your iPhone X with the most advanced QC3.0 (Qualcomm Quick Charge 3.0) charging to provide you with fastest possible charge.
RAVPower 24 W Car Charger
RAVPower is a trustworthy brand for its quality-built products. This 24W car charger is one of the best options for phones that support Qualcomm’s fast charging-standard. It’s Type-C and iSmart 2.0 USB provide a powerful combined output of 4.8A to simultaneously recharge two devices at full speed.
More than One Socket: Many car chargers are designed with multiple sockets, so it can be used by more than one device simultaneously. The multiple ports usually come with different specifications, which can output convenient charging for different devices in optimal speed. In this case, the car charger with multiple ports can be shared with your family and friends to avoid power off dilemma.
Physical Size: Generally, there is not much space around the cigarette/power port on your car, so you are better off to choose a car chargers with a small size.
Cable Length (if a built-in cable included): If you buy a car charger with a built-in cable for your iPhone X, then you need to consider its length — make sure that it can easily reach from the charger to a vent or dashboard mount. But a car charger with only an integrated cable is not a suggested option as it limits the devices you can charge, and more importantly, you have to change it with a brand new one if the cable is broken.
What You Can Choose
Here are some reliable products you can choose from with all the above features balanced.
Aukey 36W PD Charger: It fast charges your iPhone X without any problem and features two ports — one for USB-C devices and another for USB-A devices. It is also small in size and worth buying with low price.
Anker 54W PowerDriver+4: This Anker car charger comes with 3 USB-A port and 1 USB-C port which can perfectly satisfy your need to share your charger with your family members and friends. What’s more, it can fast charge your device without doubt as its 54W charging capacity.
If you want to really take advantage of Apple’s fast or wireless charging, here are some recommended products with wireless rapid-charge technology, USB-C to lightning cable, or USB-C charging.
Zendure Q3 Wireless Charger
Zendure A3TC Portable Charger
FEEYOO USB C to Lightning Cable
Faracent USB C to Lightning Cable
As there are more and more products come into the markets with similarities, it is not an easy thing to pick one from thousands of them. The products above are carefully picked by going through many reviews, in hopes that you can find the optimal one for your iPhone X.
Leave a comment
