Best Global Travel Adapter 2018
Are you a frequent international traveler? If yes, it means you’ll be carrying a phone, a camera, maybe a laptop and probably a few more things, like portable speakers or an electric razor. You’ll need to charge all those items from time to time, and while you’re traveling, you need to have an adapter to use your electronics and appliances.
The plugs that are standard in your home country are not standard in other countries. So here is when global travel adapter works. However, when it comes to choosing global travel adapter, there are few tips you need to bear in mind.
International Adapter
If you buy a travel adapter, an international adapter is recommended. Plugs can vary from country to country. An adapter that works in France won’t work in Australia or Japan. If you buy one suitable only for European plugs, you’ll need another one for Australia, South Africa, and so on. International travel adapters are great because they’re designed to provide different plug options all over the world– all in the same compact item!
USB Options
Nowadays, with all those phone cables, different chargers, etc., getting an adapter with a few USB entries (at least two) would be the most intelligent option. Actually, the best travel adapters are equipped with more than one USB port.
Size
There is a considerable difference in size if we compare regular adapters (suitable for just one type of plug) and international travel adapters (for all types of plugs). Of course, international adapters tend to be bigger and bulkier because they have a more complex design to work with several plug types.
Instruction and Certification
If you have any doubts about your electronic device, read the instructions to be sure about the voltage and other characteristics. If you aren’t sure about the quality of your device and your travel adapter, check if it has the proper certifications: the CE for Europe, the FCC for the USA, the CSA for Canada, the RCM for Australia, etc.
As you probably know, every region of the world has different sockets. In some countries, you can find several types of sockets! And sometimes even Papua New Guinea and Brazil don’t have the same plugs.
Electric Currents
Sometimes you can also experience problems with electric currents. For example, Europe uses an alternating current electricity voltage of 220V, while Japan uses 100V and the USA 120V. Some electronic devices would work just fine in other countries but you have to be careful. There are some exceptions depending on where you’re traveling and the type of electronic device you’re using.
Recommendation
Based on the above considerations about the travel adapter, one of the most popular adapter in 2018 is Zendure Passport Global Travel Adapter. This model is beautifully designed and includes built-in power adapters for nearly every region of the world.
And following are features that create added value for it.
First, it has an auto-resetting fuse. Zendure Passport is the World's First Global Travel Adapter with an auto-resetting fuse. The auto-resetting fuse (patent pending) allows Passport to recover from overloads without service or replacement.
Second, easy “press and slide” button gives you a pleased experience. With Passport, you only need to use one hand to push the country buttons, and slide to extend the power connector directly.
In addition, it has four powerful USB ports. Zendure Passport is the smallest international travel adapter with four powerful USB ports (5A/25W max), the highest in the industry.
Last but not least, as a worldwide universal charger, you won’t regret it if you buy it. Passport travel adapter covers more than 150 countries with USA/UK/EUROPE/AUS/CA/JP plugs, which and be worked in USA, UK, Europe, Canada, Japan, Mexico, Brazil, Central America, South America, Asia, the Middle East etc.
It’s important to have a reliable travel power adapter to bring with you in your journey, go with Zendure Passport travel adapter.
Leave a comment
