Flash Sale! SuperBase V 4600 for $2299 only, $4098 to get the SuperBase V 4600 and Satellite-battery 4600. Shop Now!
Backyard camping is a great way to enjoy the outdoors while staying cozy and close to home. With just a few basics, anyone can build an exciting campfire and spend quality time relaxing in the backyard. Whether you’re a first-timer or a camping veteran, this guide is the perfect resource to help you get the most out of your camping experience.
It offers a unique blend of freedom and convenience, making it an ideal choice for families, couples, and solo adventurers. With almost no setup or preparation required, it’s the perfect way to quickly and easily go outdoors for a night or weekend. Furthermore, camping can be done any time of the year, meaning you can enjoy it no matter the season.
Backyard camping has several great advantages. For starters, it’s much more affordable than traditional camping since you don’t have to purchase or rent a tent or camping gear. Plus, since you’re camping close to home, you can take advantage of home comforts like shelter, power, and Wi-Fi. Finally, with a backyard campfire and all the accessories that come with it, you can create an immersive outdoor atmosphere that lets you and your loved ones relax and enjoy nature in a completely controllable environment.
Whether you’re looking to shake up your weekend routine or add some spice to your summer holidays, camping is an enjoyable and affordable way to explore nature at home. And with the tips, tricks, and ideas outlined in this guide, you’ll be well on your way to having a fun and safe courtyard camping experience.
Selecting the Right Spot for Backyard Campsite
When planning your backyard camping experience, it’s important to consider where you will set up your campsite. It’s best to choose a spot that’s level and not too far from home. Look for an area that is safe and free of obstacles like rocks or roots. You’ll also want to consider the weather, the sun or shade the spot receives, and whether the area has water access.
Choosing the right location can make or break your outdoor experience. Therefore, planning and ensuring you have the perfect spot to enjoy camping is important.
1. Level Ground
When choosing the right spot for your backyard camping, choosing a location with level ground is important. The level ground will make it easier to set up and take down your campsite and make your sleeping quarters more comfortable. A good campsite should provide enough space to pitch your tent and have plenty of room to move around. It’s best to choose a spot that is even and free of rocks, roots, or other obstacles.
This will help ensure that your camping experience is enjoyable and safe. You’ll want to avoid spots with large slopes and uneven ground, as they can be dangerous to navigate. Finding a level spot will pay off in the long run with a comfortable and safe campsite.
2. Shade
When camping in your backyard, it’s important to consider the sun and shade your spot will get. It’s best to find a spot that offers plenty of shade created by a large tree or some nearby shrubbery. This will keep you cool and prevent you from getting sunburned, which can be uncomfortable when trekking outdoors.
Shade also helps to protect your skin from the harsh UV rays of the sun. The shade will also help keep your campsite cooler, providing a more comfortable sleeping environment. The amount of shade your spot will get makes your camping experience much more enjoyable.
3. Privacy
When planning your camping spot, it’s important to consider the amount of privacy the area offers. While camping around your home, you still want to enjoy some alone time or secluded conversations with your friends or family. The best way to ensure this is to set up in an area that offers privacy.
This could be in the form of trees, bushes, or other foliage that can block you from curious neighbors or passersby. If camping in an open field, create your privacy by strategically positioning your tents and camp chairs. Consider what you need regarding privacy and adjust your camp setup accordingly.
4. Water Source
Access to water is a key element of your camping experience. You will need water for washing dishes, cleaning up, and drinking. It’s important to stay hydrated while camping, so having a reliable source of water nearby can make a big difference. If you’re lucky enough to have a pond, river, or stream nearby, you can use it to fill up your water bottle or containers. If not, ensure your group has enough drinking water and containers.
Additionally, having a nearby water source can also be helpful in case of a fire emergency. Since your camping site is close to home, you should have a reliable water source nearby. Knowing you have water nearby can give you peace of mind while enjoying your camping experience.
5. Fire Safety
One of the main components of any outdoor camping experience is a fire. Starting a fire is a great way to enjoy your evening and make delicious food. However, it’s important to ensure your fire is safe and contained. Fire safety includes maintaining a safe perimeter between the fire and the rest of the campsite. It’s also important to keep campers away from the fire and never leave it unattended.
Looking for a fire pit or designated fire area away from nearby trees, shrubs, and tents would be best. Ensure that your fire is contained and that you have supplies to extinguish the fire quickly. Taking time to practice fire safety can make your camping experience safe and fun.
6. Insect Control
Insects can quickly ruin an otherwise enjoyable camping experience. While you can’t control Mother Nature, there are a few things you can do to deter mosquitoes, gnats, and other annoying insects from ruining the evening. Use bug repellent and light citronella candles to help ward off the bugs. You can also invest in a bug net to create an insect-free zone for your campsite.
Keep your campsite clean and free of food and garbage that attract bugs. Taking extra precautions can help keep the bugs from ruining your camping experience.
Checklist of Essential Camping Gear and Supplies
No camping trip is complete without the right gear and supplies. Whether a full weekend getaway in your backyard or a short overnight stay, having the essentials will help ensure a safe, comfortable, and enjoyable experience.
Pack all the basics such as shelter, sleeping, cooking, eating, fire-making supplies, and plenty of entertainment. Here’s a backyard camping checklist of essentials you’ll want to bring when packing for your courtyard camping trip.
1. Shelter and Sleeping:
  • Tent
  • Sleeping bag
  • Sleeping pad or air mattress
  • Pillows
  • Blankets
  • Ground cloth
  • Camping pillow
  • Camping hammock
  • Sleeping bag liner
2. Cooking and Eating:
  • Portable grill or stove
  • Fuel for grill or stove
  • Cooler with ice
  • Plates, bowls, cups, and utensils
  • Pots and pans
  • Cooking utensils
  • Dish soap and sponge
  • Trash bags
  • Napkins
  • Tablecloth
  • Food prep & dish-washing supplies
  • Camping cookware
  • Food and snacks
  • Axe/hatchet
  • Water jugs
3. Lighting and Fire:
  • Flashlights or lanterns
  • Matches or lighter
  • Firewood or fire starter
  • Fire pit
  • Camp light
  • Candles
  • Camp stove
  • Portable campfire
4. Miscellaneous:
  • First aid kit
  • Insect repellent
  • Sunscreen
  • Folding chairs or camping chairs
  • Table or picnic blanket
  • Entertainment (books, games, music, etc.)
  • Water bottles or hydration system
  • Zendure 400W Portable Solar Panel
  • Binoculars
  • Toiletries
  • Camping toilet
  • Cord, rope, and duct tape
  • Shovel
  • Personal care items
  • Sunshade
  • Footprint/ground cloth
  • Extra stakes
  • Hammock
Recommended Backyard Camping Trip Ideas
Backyard camping can be an incredibly fun and relaxing experience. You can make your camping trip special with these recommended backyard camping ideas and activities.
1. Stargazing Night
Unplug from the world and reconnect with nature by spending the night under the stars. Bring your binoculars, blankets, snacks, and camp away from street lights and distractions. Take a moment to look up and marvel at the stars, track meteor showers, and explore the night sky. If you’re lucky, you might even catch a glimpse of the Northern Lights.
2. Outdoor Movie Night
Gather family and friends to enjoy a movie night under the stars. Ensure to bring several blankets, a projector, and speakers so everyone can get comfortable watching the movie. Start with some snacks and drinks, then cozy up and prepare for an unforgettable evening in the backyard.
3. Scavenger Hunt
Organize a backyard scavenger hunt for the kids or the entire family! Create fun clues or tasks for them to complete, then introduce a time limit or even a prize for the team with the most items. Not only will the kids have a blast searching for items, but it’s also a great way to get everyone moving and exploring the outdoors.
4. Ghost Story Time
What’s more exciting than wrapping up a perfect day of courtyard camping with a spooky ghost story? Invite your friends and family to gather around the campfire and share ghost stories. Ensure each story is appropriate for the group and isn’t too frightening! If a story is too scary, have everyone take turns adding humorous details to lighten the mood.
5. Nature Walk
Take advantage of the great outdoors and explore nature by going on a nature walk. Grab a pair of binoculars and head out searching for birds, insects, and other wildlife. Keep a journal to document the amazing discoveries you make. Not only will you get to appreciate the natural beauty around you, but you’ll also get to learn a bit about the local flora and fauna.
6. Scavenger Hunt
7. Picnic
Bring the indoors outdoors! Have a picnic in your backyard and enjoy a relaxing meal without worrying about pesky mosquitoes or the weather. Set up a picnic blanket, pack some snacks and drinks, and if you feel like it, you can even bring a few lawn games and some music. Take the time to enjoy the fresh air, the scenery, and the wonderful company you have!
8. Build a Backyard Firepit
No backyard camping experience is complete without a firepit. Head to the supply store and grab some firewood or look for dry wood from your yard. Lay out a friendly circle of stones and set up your fire pit—you can even add some chairs to make the space extra inviting and cozy. Roast some marshmallows and swap stories with loved ones as you appreciate the warmth and flame of the fire.
9. Sing Campfire Songs
Create a karaoke-style atmosphere by the campfire and break into song! As you take turns singing your favorite old-fashioned campfire songs, let each voice take center stage and embrace the joyous melodies. Make sure to bring along some instruments—from guitars to harmonicas to tambourines—so everyone can have a chance to contribute. A night of campfire singing will surely be an enjoyable and bonding experience.
